Originally Posted by
surfsup
Arjand is wrong. You can add turret models for live holders or lathe tools. You need the STL model from Sandvik. then orient it correctly (along "X" on the machine). Then open the file with the LB machine. Add a solid on the turret, browse to the location, etc, and associate it to the turret station you want - tip, you can use the same solid on multiple locations if you have 2 or more of the same holder. You only need one STL. Save the file (be sure to set "embed solid into file")
