Hello all.
I need to know what it means the error code:48, on a OSAI OS3-FW-400-10 servo drive.
Can somenone help me with this?
Regards
Hello all.
Regards
Hi Error 48
Bus undervoltage Bus voltage too low. Input mains voltage too low Ramp Down 400V supply insufficient
If you are based in the USA then [email protected] should be able to assist.
Hi!
On simular drive i have error code: E-53-08-00
- what it means?
Hello. I have the same error E48 on the drive. And I cannot start the machine to activate servo motors of x, y, axis .. For a moment the machine turns on and writes servo axis Z E 001
When the CNC detects a non-critical error, it indicates it through the message in the Data .... Management of the CNC's and the PCs OSAI file system. ...... 48. “Set Up” – “Search in Memory”. Search in memory: is the search for point in the program where it was ...... 33/5 = Error during OS3 firmware upgrading.
