586,094 active members*
4,054 visitors online*
    Feb 2005
    53
    Question Visual Mill 6
    Hi Guys and Gals,
    I am trying to get my CNc Mill to perform a circle in the Y and Z axis without moving the X axis.
    I have generated a circle to use as the region but instead on cutting around the circle I get a slit along the y Axis. (No travel in either the X or the Z axis)
    How do I get it to perform this task.
    Prboz
    Apr 2004
    5737
    Re: Visual Mill 6
    Why do you want to do that? Have you got your stock mounted vertically, and a right-angle spindle?
    Andrew Werby
    Website
    Feb 2005
    53
    Re: Visual Mill 6
    Not really,
    I am setting up a hotwire to cut a cone from foam for a model jet. I wanted to hold the wire still at one end and use the y and z axis to cut the shape of the fuselage it needs to marry up too.
    Regards
    Aug 2010
    599
    Re: Visual Mill 6
    What tool path are you using? Sounds like you need to use the engraving tool path so the tool just blindly follows whatever curve you draw.
    warmachinellc.com
    Apr 2004
    5737
    Re: Visual Mill 6
    I don't see how that would work, at least not all in one go. How about setting the foam on a rotary table and rotating it against a wire shaped to your curve?
    Andrew Werby
    Website
  1. Visual Mill 6.0
    By ibrich in forum Visual Mill
    Last Post: 08-14-2014, 09:48 PM
  2. Visual Mill 5.0
    By gda in forum Visual Mill
    Last Post: 12-07-2011, 04:17 PM
  3. Visual Mill 6.0
    By iGAK in forum Novakon
    Last Post: 02-05-2011, 03:33 PM
  4. Visual mill
    By merritt boyd in forum Mach Software (ArtSoft software)
    Last Post: 06-30-2007, 11:24 PM
