586,437 active members*
4,229 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Linear Actuator Rails and Carriage
    Jun 2014
    Hello,
    I am trying to design and build a simple linear actuator. The purpose is to learn from this initial project before buying and building a full CNC mill and lathe. The far out goal is a CNC mill and lathe that can cut metal pieces with diameters <90 mm and lengths <100 mm. The parts will need to be about .01 mm tolerance. Though for right now I am just building a linear actuator that will most likely be shorter than 160 mm.
    I will most likely use a rolled ball screw, two back to back angular contact bearings, a journal bearing for the floating end and now the question is the rails and carriage system. I am trying to figure out the most rigid and cost effective solution for rails and carriage. I read the ball screw basics thread and that was fantastic. I was wondering if anyone knew of a truly comprehensive thread on the topic of rails and carriages for linear actuation. I have been scouring through threads and learning quite a bit but would benefit from something more comprehensive.
    I am getting some mixed reviews on one rail verse two. It is clear that two will be more rigid but I am always wary of making perfect alignments at a home shop. As well, two rails will be more expensive than one.
    I also need to learn more about proper methods for attaching the rails and the bearing mounts, as I don't want to negate any expensive accuracy and rigidity with poor methods of attachment.
    Feel free to add in any tips on building a ball screw linear actuator, all help is very much appreciated.
    How many bearings you need?
    Mar 2006
    2712
    Re: Linear Actuator Rails and Carriage
    The linear guideway manufacturers publish on-line catalogs. These catalogs have very instructive tech sections that have all the info you might need.
    Dick Z
    DZASTR
    Dec 2013
    18
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    If you still need help after this^ then you can try the following site...
    http://www.motionmarketplace.com/marketing/nb/
    Good Luck,
    Frank
  1. CNC Router Parts Linear Carriage???
    By NorthridgeFab in forum Linear and Rotary Motion
    Last Post: 02-10-2012, 01:28 PM
  2. MLA Mini-Actuator: PBC Linear’s Solution to Bio-Tech Linear Motion
    By Pacific Bearing in forum News Announcements
    Last Post: 05-07-2009, 07:35 PM
  3. PBC Linear Expands the PL Series by adding the PLB Linear Actuator
    Last Post: 03-06-2009, 09:58 PM
  4. Cheaper Linear Carriage maybe
    By FandZ in forum DIY CNC Router Table Machines
    Last Post: 11-09-2008, 04:46 AM
  5. Rails to bearings to carriage to... drive system?
    By Losos in forum DIY CNC Router Table Machines
    Last Post: 01-11-2005, 07:40 AM
