586,103 active members*
3,519 visitors online*
IndustryArena Forum > CAM Software > Hypermill > holder contour in tool data base
    Hello
    I am currently trying to build up the tool data base. I got the models of the holder as IGES and now I want to save it’s turning contours as DXF so that I can insert it later as geometry in the data base.
    Can anybody give me some advice?
    Many thank in advance
    Hello
    why don’t you try to get the data of the holder as DXF??
    Nowadays you can get them from most manufacturers.
    Otherwise save a cutting curve through the step and as DXF
    Regards
    CAM alex
    Hello
    Regards
    CAM alex
    sorry IGES- try to create a Solid and then the cutting curve
    Regards
    CAM alex
