586,032 active members*
2,857 visitors online*
    Aug 2011
    5
    Smile Yang SML-20 Turret Alignment
    Hello All,
    I am getting ready to align turret and reset "X" zero point.
    Was wondering if anyone had a maintenance procedure for doing this. We have a "maintenance" manual, which basically tell you how to lube, and read alarm codes, but nothing on mechanical adjustments.
    I also went to the Yang web site which was also no help. Any links, etc would be greatly appreciated.
    I have specialized in Hatachi-Seike for a number of years, but my new employer has a YANG! So it loanoks like I'm stuck with the assignment. (I'm tired of shimming tools, and using brookfield holders to indicate drils)
    Anyway like I said I will be grateful for any help with info.
    Thanks!
    TommyBaby in Phoenix
    Dec 2009
    953
    Re: Yang SML-20 Turret Alignment
    it is simple to do it
    first take a gauge 0.01mm per division with a holder and put it in the chuck
    for this i usualy use a drill or some grinded tool for measure
    i put the tool ,for example in tool post 1 or any other position u like
    go offset and assure that there is no geometry or wear inserted in the tool no 1 (or any other tool you choose)
    than i go MDI and say T0101 X0 EOB insert ,feed on minimum,press start and let the turret go to the X0 position
    move the Z axes till the gauge and adjust the gauge to touch the exterior of the drill or whatever grinded piece you insert in post 1
    adjust the gauge to indicate 0 position on it
    rotate the chuck a full round circle 360 degrees around the drill
    you will have 2 values in the X direction and 2 values on the opposite direction ,perpendicular on the x axes
    if you want to put the drill on the center of the chuck just move on MPG mode the x axes up/down untill the gauge will indicate 0 in both sides ,paralel with the x axes.
    when all is done go to machine position,check the x axes value and enter that value to the workshift of x axes in offset,workshift
    so in x direction the turret is aligned
    if you want to align in the other direction,perpendicular on x axes you have to loose the internal screws of the turret and with the help of a plastic hammer you can adjuste it(please check if you have any pins inserted inside)
    if you want more details don't hesitate to ask me.
    a simple and fast sketch for you (dont laught about my paints abilities,no time for pro drawings in solidworks
    Attachment 241984
  1. SL 10 turret alignment?
    By garylb in forum Haas Lathes
    Last Post: 08-12-2011, 03:16 PM
  2. turret alignment on sl 40
    By cherokeechief79 in forum Haas Lathes
    Last Post: 03-23-2010, 11:56 PM
  3. Fanuc OT ,Yang ML25A, Turret
    By Grzesiek in forum Fanuc
    Last Post: 02-19-2010, 09:23 PM
  4. need help with turret alignment
    By wonder in forum Calibration / Measurement
    Last Post: 07-25-2008, 10:37 PM
  5. sl-30 turret alignment
    By bowhunter in forum Haas Lathes
    Last Post: 12-06-2007, 03:49 AM
