586,072 active members*
4,419 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Import of tool group
    Aug 2004
    112
    Hello
    Is it possible to automatically choose surfaces and margins when one imports a tool group? It would be otherwise necessary to make the same operation again.
    Aug 2004
    112
    While we’re at it, how can I get the operation test from the attached picture?
    Feb 2007
    121
    Hello
    You can also export geometries, there’s a checkbox therefore. But I haven’t tried that myself.
    You can delete with deleting of the file “Test” in OPS folder. The path is in your picture above. If there’s an elegant solution, I’d like to know it, too.
    Greetings
    Aug 2004
    112
    In V9 it worked via NC Util/operations/library. It could be deleted there.
    There’re many unbelievable things collecting in the course of time.
    Aug 2004
    112
    I tried to do it. Doesn’t work. It only imports original surfaces.
    I saw Cimatron choosing its editing surfaces via levels or colour selection.
    For example, the limiting contour of my limiting contour would always be purple etc.
    I hope support colleagues of Mastercam know more.
