586,465 active members*
3,691 visitors online*
IndustryArena Forum > CAM Software > Mastercam > : Mastercam: open X5 files in X2
    Hello
    Can I open files in X2 that were previously saved in X5?
    Or how do I have to save files in X5 in order to open them with X2.
    I want to keep Solid and “machining tree”.
    Many thanks in advance.
    gruß Klaus
    Jan 2002
    312
    Hi
    File, save under
    Set File type to "Mastercam pre-X5"- define the output version under options.
    However only the geometry will be transmitted!
    Kind regards
    A. Stute
    <b>InterCAM-Deutschland GmbH</b><br />Am Vorderflöß 24a<br />D-33175 Bad Lippspringe<br />Tel.: +49 5252 98 999 0<br />[email protected]<br />www.mastercam.de<br /><br />
    Is there a possibility to keep the milling options?
    gruß Klaus
    Jan 2002
    312
    Hi
    No! The problem is that new technologies and new parameter cannot be transferred to older versions as they don’t exists yet on these older versions.
    But there is another solution: update the X2 onto X5.
    Kind regards
    A. Stute
