586,655 active members*
3,624 visitors online*
IndustryArena Forum > CAM Software > Mastercam > multi-axis milling
    Oct 2008
    15
    Hello
    I am new to the programming with the multi axes functions... I would need your help!
    In my case I want to mill a propeller with a 4th axes and I have selected the function “Rotation”.
    It all worked well but I would like to rough it beforehand with an end mill because I can’t immediately take off the whole material with a ball cutter. However the function “Rotation” only supports one ball cutter.
    Can anybody help me and tell me what function I can use for the roughing process?
    Appreciate any kind of help!
    Kind regards
    Fabian
    Jul 2005
    1313
    Hello Wolle_1,
    Simply set up 3+2 and 3x roughing
    <b><!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro--><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->&quot;Bei weiteren Fragen einfach im Chat melden. mfG macmaddog. &quot;<!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc--></b>
    Oct 2006
    3342
    Well I would pre-rough with a milling head over OptiRough- first the standard job and then 3+2 with the residual material with the rougher over the Z constant for example, or contour... you have to have a look...
    <b><!--sizeo:5--><span style="font-size:18pt;line-height:100%"><!--/sizeo-->Gruß General<!--sizec--></span><!--/sizec--></b><br /><br /><br /><br /><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><b>Fräser sind Halbgötter in Blau.<br />Denn sie lassen durch Zerstörung Neues entstehen&#33;&#33;&#33;&#33;</b><!--sizec--></span><!--/sizec--><br /><br /><br /><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><u>Werbung in eigener Sache:</u><!--sizec--></span><!--/sizec--><br /><i><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->Enter the Matrix an feel the Moment &quot;<u>www.pixxelmatrix.de</u>&quot;<!--sizec--></span><!--/sizec--></i>
    Oct 2008
    15
    Many thanks for your help
    I have tried out the Optirough function already but I did not manage to program the rotational axis (4th axis) . There is the setting “rotation type” but it did not work with that.
    With the 3+2 can I also only take one ball cutter, can’t I?
    Kind regards
