586,108 active members*
3,073 visitors online*
IndustryArena Forum > CAM Software > Mastercam > what radius to use for calculation (MasterCam)
    Oct 2006
    3342
    Hello guys
    I have another problem again: I would like to post a chamfer cutter with compensation type controller. In order to do so I have to be able to tell the machine user what radius he can deposit in the tool list.
    Background: We want to produce consistent chamfers on a hard material and if applicable the user should have the opportunity of a wear correction.
    What diameter is used here????
    <b><!--sizeo:5--><span style="font-size:18pt;line-height:100%"><!--/sizeo-->Gruß General<!--sizec--></span><!--/sizec--></b><br /><br /><br /><br /><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><b>Fräser sind Halbgötter in Blau.<br />Denn sie lassen durch Zerstörung Neues entstehen&#33;&#33;&#33;&#33;</b><!--sizec--></span><!--/sizec--><br /><br /><br /><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><u>Werbung in eigener Sache:</u><!--sizec--></span><!--/sizec--><br /><i><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->Enter the Matrix an feel the Moment &quot;<u>www.pixxelmatrix.de</u>&quot;<!--sizec--></span><!--/sizec--></i>
    Hello
    With the one that you define at the bottom!
    gruß Klaus
    Oct 2006
    3342
    Hello
    Are you sure that it’s the 0,1mm one???
    You have to enter the lowest diameter that your chamfer really has, then it should work!
    gruß Klaus
