586,884 active members*
3,905 visitors online*
Results 1 to 6 of 6
    Hello
    I urgently need help. How can I automate a tooling sheet for PEPS? I want it to show tools with the data like diameter, corner radius, cutting length, unclamped length and milling/drilling depth.
    Thanks in advance
    Greetings Beni
    Dec 2007
    198
    Hello
    What version do you have? We’ve got 5.3.14.
    What do you mean with automation? Do you want it to be saved anywhere?
    As far I know all data may be in there.
    [attachment=4870:Einrichteb.jpg]
    Well ok, next week I’m going to be in the factory. Then I’ll take a look at it but I also can try it at home with the demo version before. Thanks!
    Dec 2007
    198
    I have only demo at home, too.
    But there’s no tooling sheet there!
    In the factory you can choose between html/pdf outputs. We have pdf.
    Greetings
    Ok, thanks a lot. But it should work on its own, shouldn’t it? How can I edit it?
    Thanks Beni
    Jun 2008
    39
    Hi Tequilla,
    The pdf tooling sheet is fixed!
    But you may edit a normal text sheet (.set) a little bit.
    Therefore you have to master PEPS macro language and all the variables.
    You should rather contact Camtek, they don’t mind doing little changes
    Greetings
    Yardman
