586,384 active members*
3,674 visitors online*
    Dec 2007
    198
    Hello
    Does anybody know where you can set the positioning feed of the rotation axis with 2,5D milling? ( Tcn 530)
    F999999 are a bit too much for me, I rather change it directly on the machine, but thats getting a bit too much for me now. wink.gif
    With best regards
    Narator
    Jun 2008
    39
    Hello narator,
    Your feed is fixed programmed in a Macro!
    You can open the Macro EBN.OVM and search for "F99999".
    It works best, if you type in "ape +ebn" in the opened PEPS via the keyboard.
    Then you can change it as you like.
    I guess the PLANE cycle is used!
    Or give Camtek a quick call.
    Regards
    Yardman
    Dec 2007
    198
    Hello Yardman
    Thanks for your help!
    Works perfect!
    Best wishes Narator
