Originally Posted by
Revtech
Can you give me an order things should be done in. Like what would be the first thing you would do to setup the program and so on. Thanks Rev.
I know that once you get your CNC table done you want to jump in and cut something, QUICK! Don't do it, take your time or you'll wind up breaking bits and frying your Xylotex board. This will result in even longer delays. REMEMBER, never, ever, connect or disconnect anything from the Xylotex board with the board powered up. You will let the magic smoke out (just look at all of the posts on this board about people frying their HobbyCNC and Xylotex driver boards, it's amazing!). Unplug the board from the power source before changing any wires.
The first thing I did was print out a hardcopy of the Using Mach3Mill manual. Next, I sat down and actually read the manual from cover to cover. Yes, there is a lot of stuff in the manual that doesn't really concern you at the moment (home switches, limit switches, plasma cutters, coordinate systems, etc.) but you'll actually absorb some of the material and be better prepared once you get things working. Get some small Post-It Notes or dog-ear the pages that are pertinent to your current needs such as port addressing, I/O signals, ports and pins (refer to your Xylotex manual* or Torchhead's previous post), step calculations and motor tuning, etc. Almost all of that information is found in Using Mach3Mill Chapter 5: Configuring Mach3 for your machine and drives.
*You did print out your Xylotex manual and read it, too, I hope.
Start with one axis, say the X-axis, and get it working to your satisfaction. This may take several hours, or several days, of tweaking. Take notes. Once you get one axis behaving properly, setting up the other 1-3 axis is pretty much a snap.
Then you get to try air-cutting a few objects. Start simple with a few squares, circles, triangles, etc. and watch for lost steps, motor lock ups, and other erratic behavior. Adjust your motor tuning as necessary. Just like driving a vehicle, fast is not always the best. If everything is OK, try a more complex air-cut like the roadrunner g-code included with Mach2/3. If that goes well, then it's time to start butchering wood and plastic.
Check out the Mach3 Video Tutorials, especially the following:
1) Downloading and Installing
2) Hooking up Inputs and Outputs
3) Screens - An Overview
4) Coordinates / Homing
The videos that Art has provided are a valuable resource and time saver. Make sure you take a look at them.
Mach3 is a powerful program, take your time to fumble through the various screens and setup parameters. You'll be better off in the long run. There probably isn't a single Mach3 user on this forum who has used the simply "set it and forget it" approach to Mach3. We are constantly adding features to our tables and finding out what all of the "other" Mach3 screens, buttons, controls, and input fields are for.
Another helpful hint: Label all of your wires. This will avoid confusion and mis-wiring. While you may know which wires are which now, I'll bet it's a different story in a couple of weeks or months.
Remember, it's the journey,
HayTay
HayTay
Don't be the one that stands in the way of your success!
