Hello everyone
We are using Solid Cam for several years now and we are quite satisfied with it, part from the simulation of the programs.
To get a quick overview how the machine is running “tool path on CAD model” is completely satisfying. However with more complex parts we often look at it with “Solid Verify”. I think that works pretty bad though. Only the particular end points are approached. The path in-between that the drill/cutter goes is not visible. When showing it with “play” in the simulation, it only give a short look and then the fun is over again … =(
With other CAM programs for only a few hundred Euros, one is already able to see a fluid simulation in real time. Does that also work with Solid Cam or we simply don’t know how?! I have tried all of the different Simulation types.
Here a short example for a competitor’s software- that’s how it should look like! =)
http://www.youtube.com/watch?v=B0ZPff-ZMFE...Yuau0ghrIz9sj8=
Regards
