Hello
If one wants to readout DXF files, one gets a possibility to set the resolution.
Standard is 0,1. My question is: how is it possible to change the standard resolution?
Hello
NC-Programmierung <br />Tel.: +49 7161 301-659 | Fax: +49 7161 301-118<br /><br />ALLGAIER AUTOMOTIVE GmbH | Ulmer Straße 75 | 73066 Uhingen | Deutschland <br />Geschäftsführung: Helmar Assfalg (Vorsitzender), Gerd Plettendorf, Dr. Jürgen Ladwig <br />Sitz der Gesellschaft: Uhingen | Handelsregister: Registergericht Ulm HRB 722356 <br />Besuchen Sie uns auch im Internet: <a href='http://www.allgaier.de' target='_blank'>http://www.allgaier.de</a>
Just change it in the database.cnf!Hello
It can’t be changed in my configuration, at least not in the windows I know. Is it possible to make this with .txt?
[attachment=5245:CNF.jpg]
No, open database.cnf, there PUT DXF, then the value you want to have, SAVE EXIT.It can’t be changed in my configuration, at least not in the windows I know. Is it possible to make this with .txt?
Then it’s set in general.
In case of files that are being used, CNF RESET. This way you’ll get settings from your database. It works almost for everything.
Greetings
Yeah, I know this procedure. But the value one sets in the database isn’t saved.
That’s why I asked if there’s another possibility. (Version 3.4 R02)
The value that is set in Put DXF doesn’t even remain for the whole session. It gets lost when the window Put DXF is closed.
