You can import the CAD file with get CAD into a empty CAD file with your color table - make attention that the layer will be created new. Then it should keep the colors of the data set and your color table should also be back – provided that all mentioned colors of the data set are included in you color table – otherwise it should correct some colors.
The other possibility:
Since 3.5R2 you can choose within the Get interface to change only fixed areas of your color table – the rest stays the same.
<br /><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><!--coloro:#4169E1--><span style="color:#4169E1"><!--/coloro--><b>Alle sagten: Es geht nicht !!<br />Dann kam einer der dies nicht wusste, und tat es</b><!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--><br /><br /><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro-->Tebis: CAM Programierung, Datenbank Verwaltung, PP-Programmierung, System Administration<br /><!--colorc--></span><!--/colorc--><!--coloro:#2E8B57--><span style="color:#2E8B57"><!--/coloro-->Heidenhain: iTNC530 Anwender, Cycle-Design, Kinematic Design, und sonstige PLC Spielereien . . . .<!--colorc--></span><!--/colorc--><br /><br />
