586,055 active members*
4,424 visitors online*
Page 2 of 3 123
Results 21 to 40 of 47
  1. #21
    Oct 2007
    4
    Dear Death Adder
    Is it possible to get a copy of the G code converter? We have a Fanuc S420iF with RJ-2 controller and would like to try it out.
  2. #22
    Jul 2005
    181
    Quote Originally Posted by SteveChristie View Post
    Dear Death Adder
    Yes. In fact, I attached the program to a previous post in this thread. I do not remember if it had the EXE's or just the source code. If there were no EXE's then I could post a version that has them.
  3. #23
    Oct 2007
    4
    I got it with the exe files and all the source code. Thanks alot. I guess we won't be able to try it until we get some CNC programming software. Any suggestions? We are looking for something that is capable of creating the tool paths automatically from a CAD file or Solidworks model. The project objective is to create usable robot positional data from a CAD file with no operator intervention. We are dealing with sheat metal products that need to be MIG welded and ground smooth. Thanks again.
  4. #24
    Jul 2005
    181
    Well... I use SurfCAM. That might just be a tad pricey though for sheetmetal cutting. BobCAD is cheap as dirt and it shows. But you can probably talk their bloodsucking leech sales people into practically giving you the software.
    Still... Both SurfCAM and BobCAD are going to require someone to load up the CAD data and specify cutter dimension (everything that cuts with a beam has some width after all)
    If you know how to program it should be somewhat possible to load up the CAD data and just use a predefined beam width for your machine and have it automatically generate paths for the robot. Since you have the source code for my program you should (if you can program) be able to figure out how to generate LS files for a FANUC robot. A really large gotcha though is that programatically assuring you are cutting the outside properly could be difficult. Especially since there will probably be times where you'd like to cut the outside profile of a shape plus cut inside the profile of cutouts. This could be hard to assure within an automatic program. You really would probably be best to get a program which generates GCODE but requires some user interaction. There's just nothing like being able to see the path before you tell 10's of thousands of dollars worth of equipment to cut into hundreds of dollars worth of steel.
    Keep in mind (and everyone must keep this in mind): MY PROGRAM GENERATES LS FILES NOT TP FILES. This means, you still must use the fanuc compiler (maketp) to compile the LS file to TP for upload to the robot. I have not reverse engineered maketp so you still have to have it to do offline programming of a fanuc robot.
  5. #25
    Oct 2007
    4
    Thanks for the info on the CAM packages. I would like to elaborate a little further on our project. We are a manufacturer of electrical enclosures. The enclosures are fabricated from sheet metal. They are punched on a CNC turret press, folded on a CNC press brake, stud welded, MIG welded and ground smooth, plus spot welded. Our intention is to automate all these processes with robotics. There would be a robot that would remove the parts from the punch press and deburr them. Another robot would operate the press brake. There would also be robots that would stud weld and spot weld plus a robot that would MIG weld and grind those welds smooth. In addition to the processing robots mentioned above, other robots would be used to handle the parts for the processing robots. The long term objective of this system is to use it to produce any custom precision sheet metal part within the limits of the system's capability. To program the robots we are thinking of using a CAM type software package that will automatically produce tool paths that would represent MIG welds, grinds, spot welds, and stud welds. Is there a CAM package out there that has good tool path automation capabilities? For example, is it possible to write scripts in SurfCam that will recognize a feature (like a MIG weld on the surface of a part) and create a tool path for that feature automatically? We have been talking to a salesman at DelCam. What do you think of it?
  6. #26
    Jul 2005
    181
    Aah... I see... I was thinking that you were trying to do 2d cutting of shapes but I understand what you want to do now.
    I've used DelCam Powermill and it's a fairly decent package. Of course, I used a version from something like 2000 so I don't know what they've done since then. If I remember correctly it does work better with scripting and custom work than SurfCAM.
    What you want to do is no easy task by any means. The software I wrote so far only works in 2D whereas your project would require full 6 axis support. Granted, writing to the file is already done by my project but the hard part (and it is hard) is to get good paths for a robot that position it's 6 axes correctly. I'm not sure how well anything from Delcam will be able to do that.
    I suppose you could use the robot mode where you move the end effector in 3D plus have a 3d orientation of that effector. At that point you'd need to be sure of two things: (On fanuc robots this is called Tool positioning)
    1. You aren't hitting anything with the robot arm. This isn't that easy to figure out. However, you can mostly get away from this so long as your robot never reaches over the part. If it's always just pointing at a part in front of it then it shouldn't be able to hit anything.
    2. What orientation the end effector should be in. This is easier. For welding and grinding and such the end orientation is just an offset from the surface normal of the part at the point you are working at. For instance, for welding you might hold the gun at a bit of an angle from being perpendicular to the surface.
    Good software for doing what you want is about 15,000. There is an addon to Solid Works that allows one to program robots off of SolidWorks models. Creatively enough, it's called RobotWorks. It seems pretty nice if you've got the money to drop on it.
  7. #27
    Oct 2007
    4
    Smile
    Thanks for the feedback on DelCam. I am going to take a closer look at it. I looked into Robotworks and its requires a CAD operator to manually select the surfaces that are related to the robot paths. As I mentioned before we are looking for software that can automate these tasks. My search continues but you have given some things to check out. Thanks again.
  8. #28
    Nov 2007
    Quote Originally Posted by Death Adder View Post
    Seems like that file never saw the light of day in the downloads section... Bum deal! I'm attaching it to this post instead.
    hi
    i have the fanuc wintpe this software allows insert positions from cnc software using formats .apt,cl. o .txt using format x,y,z,w,p,r sample 100.02, 50.01, 34.45, 34.45,34.25,45.67 and no arcs. just point to point.
    does your program help me to converts gcode to any this formats.
    thanks
  9. #29
    Jul 2005
    181
    Quote Originally Posted by fierros View Post
    hi
    thanks
    Not really... The program I wrote goes from GCode directly to TP. It's exactly what the wintpe program allows you to do with .APT files but mine uses GCode files and also supports arcs. Think of my program as a replacement for WinTPE.
  10. #30
    Jul 2005
    181
    Quote Originally Posted by buidinhba5 View Post
    hi Death Adder , My company have just by an ARC Weld 100ibe of Fanuc, it use R-J3ib controller . I want to use my Robot as CNC 5 Axis and want to write a program to convert from GCode to .TP file to load into Teachpendant but i don't know about the Contruction of .TP binary file . Do you have any information about contruction of .TP file .
    Or You can help me the link about the program MakeTp of Fanuc , i can buy if it is Helpfull
    Hope you answer!
    Sadly, I do not have any information on the binary .TP format. I only know how to construct the ASCII version (.LS) which MakeTP can turn into TP files.
    You can purchase the Fanuc software directly from Fanuc but it will be something like 15000 US dollars.
  11. #31
    Mar 2009
    Talking Very Sad !!
    no one attention in this topic .
  12. #32
    Feb 2009
    59
    Exclamation Do you have this?
    The robot's control software is capable of converting a binary robot file into an ascii file. You use the teach pendant to go into the program selection screen and move over to SAVE. It will send the ascii file to a connected PC through the serial port. That's with an RJ1 robot. You might be able to hook it up via ethernet with an RJ3 but I've no experience with anything other than an RJ1.
    The correct software to interface a PC with the robot hopefully came with your robot or you purchased it seperately... Otherwise there's trouble. I do indeed have a GCode -> TP program but it still needs the maketp utility from Fanuc to convert the resulting ascii file (which is in the same format that the robot will send to a PC) into a binary TP file. Unfortunately there is no free or open source alternative to maketp. You really have to get it from Fanuc or find someone who will be willing to send it to you.
    I use maketp to compile my programs and then use KFloppy to make a connected PC appear to be a fanuc floppy drive to the robot. This allows for sending and receiving programs. Without KFloppy and MakeTP you will be severely limited in what you can do.
    I'm going to try to clean up my C# version of the GCode to TP program and upload it somewhere. Hopefully, even though I haven't had much time to commit to this, it will help someone else. And maybe, if I'm lucky, somebody will help fix it up and send the changes to me. ;-)
    I just received a Fanuc Robot S-5 with the Controller Big Box and the hand held Pendent.
    and some other stuff... What is the "MakeTP" I might have that? But I need instructions on what it is. If you have already described it I havent gotten that far in the post. I would be very much interested in being able to use my Bot for CNC stuff. I was making a CNC MIll and was going to take apart my S-5 and use the parts to make a 5 axis cnc but if this works My CNC mill/Router/ Killer Robot is already done!
    Is the MakeTP software or is it something else? VERY MUCH INTERESTED IN THIS!
    Dude you ROCK!
  13. #33
    Feb 2007
    54
    Hey,
    Interesting post...very cool. I am about to start a 5axis(I currently have a three axis using NSK spindle controllers) build and wanted to use it as a robot....can I use standard hardware(mechanical....ball screws steppes/servos and encoders) as if I was making a normal CNC?
    Or what should I look out for versus making a CNC and hooking it up to a board?
    Roger
  14. #34
    Jul 2005
    181
    Quote Originally Posted by Musick7 View Post
    Dude you ROCK!
    maketp is software. It's a console mode windows program (I'm pretty sure i've tried to run it in just dos and it will not.) that compiles .LS files into the binary .TP format for FANUC robots.
    I'm not sure where you might get it other than from Fanuc. However, they are near the lowest form of scum as far as I'm concerned. They are not going to be willing to give you the time of day or urinate on you to put you out if you were on fire. Unless, of course, you give them an exorbitant amount of money for software that the robot undoubtedly needs and originally had. I hate unscrupulous companies that do that. They are a hardware company but they try to dry up sales of used machinery by bullying people that buy used. It's not right.
    So... umm... beats me how you'd get maketp...
  15. #35
    Jul 2005
    181
    Quote Originally Posted by roger_e View Post
    Hey,
    Roger
    Robots tend to have servos which drive gear reducers and such. There really aren't ballscrews. Things are hooked up through driveshafts and gearboxes then directly to the joint. You essentially could just hook motors right up to joints. But, they are pretty much just normal servos and servo amps and all that good stuff. The real problem comes when you need to calculate inverse kinematics to figure out how to move the joints in such a way as to get the kind of movement you would like.
  16. #36
    May 2004
    One word for CAM programming robots....Robotmaster
    http://www.robotmaster.com
  17. #37
    Sep 2010
    Robots
    Hi Newbie here.
    What are the best options to take,
    Robot cutter or cnc table cutter.
    I am keen to get a machine together.
  18. #38
    Jul 2005
    181
    Quote Originally Posted by DavitCNC View Post
    How many kidneys must one sell to be able to purchase even one license of that?!? If it's anything like any other robot software I've seen it'll be at least 15000 dollars.
  19. #39
    Oct 2010
    Death Adder, you kinda rock!
    Exactly what I needed!
  20. #40
    Nice!
    old but very good thread!
    any chance to have you for Kuka files - KRL?
    keep it going man, the cnc robots are popular today - and they need software like that
Page 2 of 3 123
  1. Replies: 0
    Last Post: 07-21-2013, 11:53 AM
  2. Replies: 5
    Last Post: 03-02-2011, 02:15 PM
  3. Fanuc S-10 6HB robot
    By Trucks in forum Fanuc
    Last Post: 10-02-2009, 02:33 AM
  4. GMF Fanuc L-100 Robot R-F controller
    By whiteriver in forum Fanuc
    Last Post: 01-28-2005, 05:16 PM
