When I want to print a document with "DOCU" "PRINT”, then a white window usually opens. Is there a way that a certain frame opens instantly, without having to load a frame over "Load"?
Hi-Jan Friedel
The days of us using this type of document have long gone, but if I remember correctly you can rename a frame into std.frm and then this will be loaded by default.
Thanks for the tip that’s how it works!!!!
