586,043 active members*
3,573 visitors online*
Thread: ppd
    Hi ..
    How can I write a .ppd in which the tool position does NOT come with its own display? coangry.gif
    When I write a drilling program and I display it then each tool that has several positions appears several times in my .ppd file.
    greetings
    T.D.
    You will not manage that because the output gets attached to the end independently for each job -so the second job does not know what the first one did.
    Unfortunately, you don’t have a proper programming logic in the PPD
    like in PP, where you can go through several loops... it’s not made for that!!
    What do you want to do? Only release a list of used tools?
    That you could let the PP write that as a comment into the program, or get a second text file from the PP with a tool list. . . .
    <br /><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><!--coloro:#4169E1--><span style="color:#4169E1"><!--/coloro--><b>Alle sagten: Es geht nicht &#33;&#33;<br />Dann kam einer der dies nicht wusste, und tat es</b><!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--><br /><br /><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro-->Tebis: CAM Programierung, Datenbank Verwaltung, PP-Programmierung, System Administration<br /><!--colorc--></span><!--/colorc--><!--coloro:#2E8B57--><span style="color:#2E8B57"><!--/coloro-->Heidenhain: iTNC530 Anwender, Cycle-Design, Kinematic Design, und sonstige PLC Spielereien . . . .<!--colorc--></span><!--/colorc--><br /><br />
    The ppd file lists all used tool in the attachment.. hope that helps you out!
