586,032 active members*
2,805 visitors online*
Thread: RCORN
    Oct 2002
    829
    Hello Tebis user
    Is anyone using “re-work corners”?
    What do I have to consider?
    I currently have a component part with pretty deep and small radii...
    Please no reference to the manual or the Tebis hotline ;-)
    Kind regards Matz
    <span style='font-family:Times'><span style='color:blue'><span style='font-size:14pt;line-height:100%'>Nicht alle Schalker sind Psychopaten - aber ich</span></span></span>
    There is not a lot to consider..
    RCorn is only for reworking one corner. Related to Rfill because only ball cutter work- as the tool and as the forerunner.
    You can clear the corners in several steps by dividing the maximum depth into several cutting depths.
    e.g. max depth = 2mm cutting depth=0.6 means 3 steps a 0.6mm and one with 0.2mm.
    You can decide in the CNF when processing fillets if you want to do the step with 0,2mm first or at the end ( more practical)
    Regards
