586,094 active members*
3,896 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > PPD kind of tool compensation exit
Results 1 to 3 of 3
    Hello,
    Could I ask, how the exit of the PPD file kind of tool compensation?
    For example:
    Type: Profile or type: centre RC or Type: centre
    I guess that you want to use railway type radius correction or wear correction of a PPD file!?!?
    As far as I know there is no variable that you can use to find out the railway type. Maybe that is extended with the R2, so you could ask there.
    An up-to-date PP-manual would also be not bad
    <br /><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><!--coloro:#4169E1--><span style="color:#4169E1"><!--/coloro--><b>Alle sagten: Es geht nicht &#33;&#33;<br />Dann kam einer der dies nicht wusste, und tat es</b><!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--><br /><br /><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro-->Tebis: CAM Programierung, Datenbank Verwaltung, PP-Programmierung, System Administration<br /><!--colorc--></span><!--/colorc--><!--coloro:#2E8B57--><span style="color:#2E8B57"><!--/coloro-->Heidenhain: iTNC530 Anwender, Cycle-Design, Kinematic Design, und sonstige PLC Spielereien . . . .<!--colorc--></span><!--/colorc--><br /><br />
    Could you help me? How can I export the type of the replaced tool from the PPD? Thanks very much!
