586,065 active members*
4,349 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > use Wildfire files in Work NC
    Would anyone of you like to tell me how to open files from Pro Engineer Wildfire in NC Work...
    So I can edit it....
    Looking forward to any answers
    LG Steffi
    Hello
    You should be able to open the file using the direct interfaces of NC work.
    However for the interface you need an extra license.
    Alternatively, you can save the files from Pro Enginner as IGES files and then open them with WorkNC.
    &quot;Lache nie über die Dummheit der anderen. Sie ist Deine Chance.&quot;<br /><!--sizeo:1--><span style="font-size:8pt;line-height:100%"><!--/sizeo-->Winston Churchill<!--sizec--></span><!--/sizec-->
    Thank you a lot
    It worked well with the IGES files. When I tried to open it over the interface, then the license error came up..
    Thanks!
    Kind regards
    Steffi
