586,357 active members*
2,860 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Clearing of a borehole
    Hello
    How can I clear a 80mm borehole in a helix with Gibbs?
    Regards
    Kiki
    HAAS VF7 - BJ2008<br />HAAS ST20<br />HAAS ST10 mit Stangenlader<br />HAAS Mikron VCE1000<br />EMCO 365<br /><br />www.KDC-Technik.at
    Do you mean a top down helix or a helix in the XY level?
    A top down one works via the plug-in Z-contour ramp with any contour.
    Hello
    I mean in XY
    Regards
    Kiki
    May 2005
    70
    Hello
    Finally life in the Gibbs Forum
    Menu “Plug-ins – geometry – create helix” and/ or “Manual for plug-ins (Gibbs 2007)” page 73
    <b>Viele Grüße,<br><br>HeinerT</b><br><br>Wenn der Fräser raucht und stinkt, er in den Werkstoff dringt.
    Hello
    It’s not exactly that what I mean.
    I wanted to clear an 80mm hole with a 12mm cutter. And that in a helix. Outside will be made a circle or two.
    Regards
    Kiki
