586,104 active members*
3,320 visitors online*
    Hello everybody
    I am currently looking for a solution for the date exchange from the PC (Windows XP) to the milling machine (Deckel / Maho). The machine has a Dialog 112 controller.
    I already looked through the whole forum but I couldn’t find anything useful:
    I have the following questions:
    1) What programs are suitable for the data exchange and where can I get it from?
    2) How does the connection plug arrangement needs to be or are there finished cables?
    3) What parameter do I need to set on the machine?
    I would really appreciate if anybody can help me out =)
    Hello
    On my homepage www.industrielle-it.com, you can download CimcoFTP.
    If you give me your data, I can generate a test key for you.
    Most Dialog 112 can communicate over the network.
    With the program we can test it together..
    Regards Andres
    Andreas Poggel - industrielle IT<br />Wuppertal<br /><a href='http://www.industrielle-it.com' target='_blank'>www.industrielle-it.com</a><br />
    If they have a network card ....
    Regards
    Sven
    Nov 2011
    14
    You can use the program Hyperterminal for example.
    I don’t know how you need to arrange the plugs; it should be described in the brochure that comes with the Dialog controller.
