586,033 active members*
2,894 visitors online*
    Hi
    I'm have the following problem on my Deckel FP4AT with Contour3 controller:
    I need to produce a cube-like component part with an annular groove on each side. Now I would like to describe this groove in a macro and call in every program for every side at a specific location.
    Now to my problem:
    I go to my macro list when I press %0* Then I create a macro program, e.g. % 0 * 1 and then try to select it.
    Nothing happens ....
    a normal program can selected. I also have the problem with a local subprogram.
    Who can help me???
    Greetings Adam
    I have not worked for ages on this controller.
    As far as I can recall it, the editing the macros is similar to the N *- sentences: Usually you need to use a key combination to switch in the program editor. Try it with FKT%.
    greetings
    cgTNC
