Hello everyone
My question:
Does anybody know if polygon milling is possible to do on a Hardinge GS 250 turning machine with Fanuc Oi-TD controller?
If yes, how?
Hello everyone
My question:
If yes, how?
with ManualGuide and powered tools
And if I don’t have manual guide?with ManualGuide and powered tools
Can I simply program it on the machine?
Can’t anticipate that... not even with a ball....
How well is your machine equipped?
Y-axis?
C-axis?
Powered tools?
How familiar are you with the controller and the machine?
What manual have you got- do you have any manuals to the controller and the machine?
The machine doesn’t have a Y axis but a C axis.
Powered tools: yes
I do hexagon milling on the face side but now i also want to mill a hexagon on the side of the jacket. However I can only do that with a polygon milling tool.
Could you give me a sample program?
If the multi-edge-profile is not too far away from the work piece zero point then you can also do it with abutting face cycle and T keyway cutter.The machine doesn’t have a Y axis but a C axis.
Powered tools: yes
Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
Without Y axis a proper hexagon can only be achieved in the way InTex described it.
With the Polygonal turning, a special tool is run in a spindle synchronic way. The function is an option. If you don’t have ManualGuide, then it’s very likely that this option is also not active either.
G51.2 (G251) P_Q_;
P,Q: turning relation between spindle and
Y--axis
Area defined: Number from 1-9 for
P and for Q
With a positive Q, the Y axis turns in a positive direction
With a negative Q, the Y axis turns in a negative direction
G51.2 P1 Q3 (Polygonal turning ON)
G50.2(G250);
When G50.2 is set, the synchronisation of spindle and Y axis is cancelled, and the Y axis stops.
Hello
Yes, of course if
- The machine is fitted with a C axis.
- The OPTION G112 (G12.1) is installed
- Kind regards
Daniel Alber
CNCart - Daniel Alber<br />Agnes-Bernauerstr. 262<br />81241 München<br />
