586,042 active members*
3,654 visitors online*
    Hello together,
    today I did some PP-tests. Amongst as well a 2.5D programm with level transportation.
    Here I found out, that the machine doesn't referr the displacement at the actual part center point by displacement of point zero via CQA, but rather as well to the in the program transformed pivotal axis.
    Could anybody tell me, if this could be deactivated with a command in NC-program or in controller?
    Thanks a lot in advance.
    Greets, Magmahon
    Log in at Service and than via Search convert the parameter ROTO_CQA with Enter-button.
    It might work.
    Greetings
