586,119 active members*
3,607 visitors online*
    Hello guys
    I wanted to completely turn the machine off using the procedure ( Mecof)
    Unfortunately it doesn’t work with the NIGHT OF function.
    Also the command RESET ALL cannot be used in the procedure.
    Have you got any idea??
    Nov 2007
    Simply write
    Night on
    >M02
    At the end of the procedure.
    Done!
    Through M02, the Night on gets activated and the controller gets turned off.
