586,033 active members*
3,584 visitors online*
Results 1 to 8 of 8
    I am working on a Mecof agile CS 500 with Fidia controller.
    As we process relative deep pieces, it is very time consuming always having to retract the virtual axis (w-axis) 0.3m/min with each tool breakage in order to change the indexable inserts.
    My question now:
    Is it possible to approach a tool change point in the program with HOLD or at least change the 0.3m/min with a higher value??
    Many thanks in advance
    Regards
    Hi
    Why don’t you press Pause and then roll out with the hand wheel...then you give the speed.
    Regards Karsten
    <!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->&quot;Menschen mit einer neuen Idee gelten so lange als Spinner, bis sich die Sache durchgesetzt hat.&quot;<!--sizec--></span><!--/sizec--> <!--sizeo:1--><span style="font-size:8pt;line-height:100%"><!--/sizeo-->Mark Twain<!--sizec--></span><!--/sizec--><br /><br /><br />CAD/CAM<br /><br />Programmierung - Prozessoptimierung - Automatisierung <br /><br />www.vcc-production.eu
    im "HOLD" kann ich aber keine Achse anwählen.
    zumindest bei der Fidia C10 funtioniert das nicht.
    Hello
    As Kassi already said you have to press the PAUSE BUTTON- that’s the one next to the Hold button. Then the memory goes empty and after 20-50 blocks the NC will stop. So now you can run with your W axis until China, also in rapid traverse!
    Try it out, it will works!!
    That really works =)
    Thank you guys!!!!
    The only problem it that the machine stops after 300 blocks.
    Can I shorten that somehow??
    No, that would be at the expense of the Look Ahead Parameter.
    Okay, I don’t know what that is but alright...
    However when the insert breaks then of course I have to exchange it immediately not after 300 blocks.
    Hope you can give me some advice!
