586,058 active members*
4,698 visitors online*
    Hello
    Two weeks ago I got a new VMX30U. The training involved only 3 axis milling.
    I received parts that can be processed from all their sides. Can anybody help me?
    How can I program that? The programming and milling without turning the table works superb.
    The processing that is programmed over 5 axes is a simple drilling picture but just from every single side.
    Regards
    many thanks!!
    Hello
    Regards
    many thanks!!
    The easiest method is:
    Position turning table A or B axis, set a new neutral point on the processing layer
    And then continue programming like usual.
    That’s how we do it on a 4th axis with ultimax
    By the way just negotiate about a VMX 42 U =)
    Regards Apple
    Sep 2002
    255
    Move neutral point of the turning table START
    Mill/drill
    Move neutral point of the turning table END
    Set neutral point in the 0 degree position
    With neutral point movement Start add the values where the new neutral point should be placed.
    The whole thing is always based on the 0 degree position.
    That’s it.
    However you need to set a few basic conditions need to be fulfilled: for example the rotation centre of the axis and so on…
    If you start carefully then you will see if you are reasonable correct.
    If you are unsure I would wait until you receive the 5 axis training.
    However in principle its not very hard but a few things you need to know.
    Good luck turning and rotating with your Hurco.
