586,058 active members*
3,465 visitors online*
Results 1 to 7 of 7
    Hello,
    We have 3 machines with the old c200 controllers from index: one gs30, one gs42 and one gs65. There’re full alphabet and brackets for comments on the keypad.
    So how can I write comments in a program?
    For example:
    T1212 L999 (stop)
    Is there a particular keys combination therefore?
    As a skilled programmer I’m used to comments.
    Additionally I’m searching for a boring cycle for chip breaking.
    I help myself with the deep boring cycle L98 now.
    Thanks in advance.
    Nov 2004
    26
    Hello
    I also have these controllers. So far I know you can’t write these texts at the machine.
    I write my texts in the programming space during compiling.
    They are input then and are viewable.
    Regards
    wimu
    It would certainly work at the laptop, but I think the guys from Index have meant something inserting the buttons.
    Jan 2006
    77
    You can use the keys only in the DNC mode, Index C200/T200.
    Regards, Runde
    Ok, it explains everything.
    Thanks Runde01!
    Re: C200 and entering of comments
    Hello to all
    I have an INDEX GSC42 S3TT / C200 TT.
    But there is a problem. After turning on and activating the hydraulics,
    everything is fine.
    By selecting NC1 & NC2, the X1 & Z1 & X2 & Z2 & C & Y1 axes are easily
    referenced and no error is observed.
    When the tool is called to the roller 1, the TURRET unclamps but does not move.
    After a few seconds at a very low speed that seems to be drift axis
    Spins and does not recognize the tool and continues to spin.
    And E8 & R0 & R5 errors are displayed.
    Can anyone help and guide me?
    Thank you
    Hello to all
    everything is fine.
    When the tool is called to the revolver 1, the TURRET unlock but does not move.
    In addition, the x-axis and the roller have a servo motor
    They are common and the revolver does not have an instrument counting encoder and
    has three proximity switches 1S10 =E2.0 (revolver 1 locked) and 1S3 = E0.6 (revolver 1
    tooth pulse) and 1S1 =E1.0 ( position 1)
    and two The solenoid 3Y15 =A0.0 (revolver 1 lock )and 3Y14 = A0.1 (revolver 1 unlock )
    performs the lock and unlock operation ,
    I have no documentation of this machine.
    Thank you
