586,075 active members*
4,169 visitors online*
Results 1 to 7 of 7
    Aug 2002
    428
    Hello
    We have a new Haas milling machine. I tried to import a CAM-program via memory stick to the controller. I stupidly failed to give a short name to the file. As I pressed F2, the controller shuted down. Now it happens always when i press the key “PROG LIST”. Does anyone have a sugestion?
    Regards
    Joel
    Aug 2002
    428
    Hello
    That’s me again.
    Does anyone have an idea?
    Hasn’t anyone had the problem?
    Regards
    Joel
    Aug 2002
    428
    Hello
    The machine works again. The serviceman repaired it. But all of us in the company think that something like that must not happen again. I hope we’ll get it under control.
    Unfortunately I can’t say in what way the machine was made fit again.
    Regards
    Joel
    Oct 2007
    6
    Hello
    He deleted the program memory completely.
    We’ve also had the problem.
    It’s only one of many mistakes that Haas won’t ever correct.
    Regards
    Thomas
    Oct 2007
    87
    With most of errors you just have to restart the machine
    Aug 2002
    428
    Hello Maddy
    Believe me, i tried that..
    I even removed the memory stick – that didn’t help.
    Thommes01 is right.
    The memory was completely deleted. But I don’t know how. It was made too fast.
    Regards
    Joel
    Mar 2008
    103
    What do you mean with “shuted down”? Black monitor? Automatic reset or just hang-up? Which memory was deleted? The whole machine memory with parameters etc.? Which software do you have? What diagnosis was made?
    <!--fonto:Comic Sans MS--><span style="font-family:Comic Sans MS"><!--/fonto-->Das Problem der Maschine steht 30cm vor ihr&#33;<!--fontc--></span><!--/fontc-->
