586,108 active members*
3,038 visitors online*
Results 1 to 2 of 2
    Jan 2006
    52
    Red face Yasnac LX-3 322: CMOS Vacant Area Error
    hey all-
    we recently acquired an off-brand lathe with the yasnac lx3 control. after plugging it in, the boot tests all passed ok, we overtraveled the table and had to disconnect the limit switches to try to jog it back into the safe zone. well, after removing the limit switches and booting up, we now get this
    322: CMOS vacant area error
    according to yaskawa, we have no other option but to replace the mb or the offending chip(s). based on pc computing experience, it seems that you can remove the battery and clear the cmos... can we do the same here?
    we're going to back-up the parameters first, and then give it a try...
    has anyone else had this happen before?
    thanks!
    Mini-Mill Kits and Plans - http://www.fignoggle.com
    Sieg X3 and Super X3 Mill Information - http://www.superx3.com
    Nov 2010
    hello,
    i would not post new thread - so - we have same problem: alarm 322 cmos vacant area error.
    i've googled already a bit - a solution to thsi should be to set 1 to parameter 6066.d2 to reset the error. but i cannot see this parameter inside the controller. shocked
    has somebody had a problem like this before ? how to proceed with this ?
    any advice would be great. thanks.
  1. EZ Track DX cmos
    By custom in forum Bridgeport / Hardinge Mills
    Last Post: 07-13-2008, 11:58 PM
  2. lost cmos
    By actionman in forum Tree
    Last Post: 11-14-2007, 01:58 AM
  3. cmos ?
    By MegaMoog in forum Bridgeport / Hardinge Mills
    Last Post: 09-21-2006, 03:55 AM
  4. Hitachi Seiki with Yasnac LX-3 Error
    By dannyboysd89 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-08-2006, 01:54 PM
  5. Yasnac i80 error 102
    By Boring Life in forum Fanuc
    Last Post: 04-09-2006, 12:05 AM
