586,060 active members*
3,380 visitors online*
    Hello
    When I want to enter the program for example I drive with the hand wheel to Tool 3 and start the machine first in Run in Tool 2 then Z in action and then tool 3 is first changed and then here we go
    How can I turn that off?
    Arbeite nur,die Freude kommt von selbst!
    You have 2 possibilities:
    1. Turn off Block search calculation. That has the disadvantage that you can only enter with the tool.
    2. You enter under the set with the tool, then the machine does not undertake a tool change
    The problem is that if you enter directly with the tool, the machine calculates the previous tool as well. Changes and then drives to the last position of that tool ( it’s the same when milling only the risk of collision is smaller.)
    Greetings Michael
    Gruß Michael<br><br><br><br>
    Oct 2005
    159
    Hello
    Can you enter you program here please?
    We have a 9 Haas machine and it normal to be able to start with the tool in the spindle. Block search calculation is enabled.
    Regard
    ogelle
    hello here is my little program:
    O100
    ( DEMO-D )
    ( MAGAZIN: PRO-60 )
    G54
    ( SURFACE )
    ( LFR12 )
    G17 T01 M06
    F300. S2500 M03
    G90 G00 X91.876 Y71.9
    G43 G00 Z1.0 H01 M08
    G01 Z-5.0 F150.
    G01 X87.928 F300.
    USW.
    G0Z2
    T02 M06
    F50000. S300 M03
    G43 G00 Z1.0 H02 M08
    G01 Z-5.0 F150.
    G01 X87.928 F300
    USW
    G53Z0
    G53Y0
    M30
    Arbeite nur,die Freude kommt von selbst&#33;
