Have a look here how it all started:
http://www.cnczone.com/forums/showthread.php?t=22867
Attached is the PDF schematic for one axis.
Here is a picture of a 3 axis PCB using the TEA3718SP:
http://users.skynet.be/sky50985/CNC/..._tea/3axis.JPG
Fit's nicely on a eurocard (100x160mm) but needs a double sided PCB.
Single sided is possible but would need quite a few jumper wires.
These TEA3718SP's can be recuperated from printer PCB's or even bought new for a few buck's each, a lot cheaper than LMD's if 1 Amp (or a bit more) is enough for your application.
The concept of this R2R DAC can be used for other chips also.
Suggestions and feedback are welcome.
Regards,
Luc.
