586,051 active members*
3,590 visitors online*
    Jan 2009
    7
    Hello!!
    I have the following problem: I wanted to mill a pocket, 50mm long and 13,5mm wide with round corners. Miller 8mm- error message wrong numerical data 8. When I change the width to 20mm then it works.
    But why? What do I have to change?
    Many thanks for your help!
    Mand
    Does it work with 16,5? And with 15,5?
    Jan 2009
    7
    No, then the same happens. Only works after 18,5mm
