586,036 active members*
4,343 visitors online*
    Hello
    I have the following problem:
    I want to push feather key grooves into drilled holes on a LB15II-M with OSP 7000L.
    Has anybody done that before?
    How do you program it? Variables??
    Many thanks in advance
    Hello
    I don’t know your machine but I would only position the spindle in the program to the desired degree and then push with an adequate slotting tool. wink.gif
    (path programming in iso or in variables depending on the controller)
    Regards
    Stefan
    <b><u><!--fonto:Comic Sans MS--><span style="font-family:Comic Sans MS"><!--/fonto--><!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro--><!--sizeo:4--><span style="font-size:14pt;line-height:100%"><!--/sizeo-->Ich weis nicht alles, ich lerne viel, <br />aber leider wird einem selbst das <br />lernen heute erschwert<!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--></u></b>
