586,089 active members*
3,755 visitors online*
    Hello everybody
    Unfortunately I lost the machine constants of my Maho 500 C (Philips 432)....
    I always had the machine connected to a power source but I hadn’t switched it on for a while.
    I thought as long as its connected to the power supply, the parameter could not get lost.
    Well, I guess that was a fatal mistake.
    I think that the batter that is necessary for the protection of the machine constants is not working properly anymore.
    So I want to change it. Does anybody know where I can get it from?
    What would that costs?
    And where exactly is that battery located?
    Would be nice if anybody could help me out!
    Regards
    JLS
    Dec 2001
    5151
    Hello JLS
    It’s a lead battery. Depending on the controller type you need to have a special one.
    You can find the battery over the technical information with Google. You should get a one that matches the technical data of your current battery.
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
    Morning
    I finally found time yesterday to build in the spare battery that I bought. It did not cost a lot...
    After building it in, I first got quite scared: when turning on the machine, the screen first stayed black for quite a while.... Maybe the controller had to load or something like that.
    Afterwards I “quickly” tipped in the parameter and... it worked =)
    Many thank for your help!
    Regard
    JLS
