586,072 active members*
4,390 visitors online*
    To all users of Roeder controllers!
    When the desk is overloaded and you need to run several parts of a series – then it’s necessary to switch off the breakage control so that everything is running smoohtly.
    Is it possible to secure a milling machine and jump to the next work piece in case of a breakage or wear out without having to buy the option ‘job management’?
    Many thanks for your answers!
    I am thinking for example about the jumping command like on the Heidenhain controllers (if/do and so on)
    Hello
    As a program stop is directly linked to the breakage recognition, I am not sure if that’s possible. You should ask Roeder directly, they will be able to help you.
    I know the problem from our RFM1000 when we clamp several component parts for the weekend.
    Regards
    Gerd
    Hello take –it-easy
    You could (with a lot of effort) define the breakage control yourself.
    If you set ,for example with. -broken=200 the breakage limit quite high, then you could define with an IF condition if the tool should be used or not. If not, then a M30 follows and the machine jumps to the next part.
    Main requirement would be that you increase your main.bef a step further:
    For example
    Haupt.bef:
    XCALL part1.bef // the actual commando file in which the IF condition should be in
    XCALL part2.bef
    M30
    It’s a lot of effort at the start. But when the program is done….
    Regards
    Elmoh
