586,114 active members*
3,319 visitors online*
Thread: LBL call
    Jul 2008
    55
    Hello people
    I’m sure that someone here can help me.
    I want my program to repeat 9 times but to go 10 mm deeper after each cycle. What is the best way to do it?
    Jul 2008
    55
    I forgot something. It has to stay at zero (z) the first time. Then after 9 repeats a new rod gets in and the program has to begin again from above (z).
    Hello Metall…
    I’d just move the zero point incrementally 10mm deeper
    Then lbl call xxx rep 9/9
    Then set zero point again absolutely
    That’s the way I’d also make it.
    Greetings farmer
    <b><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:6--><span style="font-size:24pt;line-height:100%"><!--/sizeo--><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro--><i>Gruß farmer</i><!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc--></b><br /><br /><br /><br /><i><!--sizeo:4--><span style="font-size:14pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro--><!--sizeo:4--><span style="font-size:14pt;line-height:100%"><!--/sizeo-->Hilfsbereitschaft, Gemeinsinn, Miteinander und Füreinander<!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--><!--sizec--></span><!--/sizec--></i>
    I agree!
    CYCL DEF 7.0 NULLPUNKT
    CYCL DEF 7.1 IZ-10,000
    CALL LBL 1 REP 9/9
    CYCL DEF 7.1 Z+0,000
    cycle numbers can certainly vary depending on the controller
    Good luck!
