586,108 active members*
3,107 visitors online*
    Sep 2008
    27
    Hello,
    How can I add an existing program afterwards in BLK form?
    Greetings Big Jim
    Hello,
    If you want to add it directly into the machine, you have to do like this:
    BLK FORM 0.1 Z X-060.000 Y-055.000 Z-064.082
    BLK FORM 0.2 X+060.000 Y+030.000 Z+000.000
    In the first input phrase the small X,Y and Z coordinates, in the second phrase the big ones.
    From a CAD program it works best with for example a postprocessor instruction, at the beginning of the program.
    For example:
    INSERT BLK FORM 0.1 Z X-060.000 Y-055.000 Z-064.082
    INSERT BLK FORM 0.2 X+060.000 Y+030.000 Z+000.000
    Best regards
    Peter
    Hello,
    Greetings Big Jim
    Feb 2006
    118
    PGM store/edit -> call PGM (if it’s not already in the memory) -> over the soft keys to BLKFORM (or something similar) -> add values, finish !
    Greetings Tooltech
    <!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro-->*Der sicherste Weg eine Arbeit loszuwerden, ist sie anzufangen* <!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--><br /><!--sizeo:1--><span style="font-size:8pt;line-height:100%"><!--/sizeo-->Robert Lembke<!--sizec--></span><!--/sizec-->
    Hello,
    To add a BLK Form afterwards , you need to use the special functions of the controller. You find it with the 530 when you click Sk on the left side and then scroll.
    Its actually quite easy.
    <b><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:6--><span style="font-size:24pt;line-height:100%"><!--/sizeo--><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro--><i>Gruß farmer</i><!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc--></b><br /><br /><br /><br /><i><!--sizeo:4--><span style="font-size:14pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro--><!--sizeo:4--><span style="font-size:14pt;line-height:100%"><!--/sizeo-->Hilfsbereitschaft, Gemeinsinn, Miteinander und Füreinander<!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--><!--sizec--></span><!--/sizec--></i>
    Sep 2008
    27
    Thanks, that's exactly what i needed!
