586,102 active members*
2,648 visitors online*
    Hello guys
    I have milled a rectangle pocket that is 54mm long and 30mm wide with the cycle 251, the machining perimeter was zero.
    Insofar everything was top. I have left an allowance of 0,5mm so first roughing, then finishing, then measuring and finally adjust the measures.
    Afterwards I copied the cycle into a different program and only changed the measurements of the length to 470mm and width to 20mm and the feed as well as the revolution because I first had a 8mm milling machine and after a 12mm one.
    Then there was the problem: I measure the flute and the width was not 20mm- it was 20,4.
    How can that be? Radius was 6mm because of the new milling machine. I have copied everything because it worked so well beforehand.
    Maybe somebody has an explanation ( control system itnc 530)
    Many thanks in advance
    Oct 2006
    3342
    Radius correction correct with both programs???
    Have you eliminated the allowance in the cycle of the first processing. I mean the allowance in the first axis??
    <b><!--sizeo:5--><span style="font-size:18pt;line-height:100%"><!--/sizeo-->Gruß General<!--sizec--></span><!--/sizec--></b><br /><br /><br /><br /><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><b>Fräser sind Halbgötter in Blau.<br />Denn sie lassen durch Zerstörung Neues entstehen&#33;&#33;&#33;&#33;</b><!--sizec--></span><!--/sizec--><br /><br /><br /><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><u>Werbung in eigener Sache:</u><!--sizec--></span><!--/sizec--><br /><i><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->Enter the Matrix an feel the Moment &quot;<u>www.pixxelmatrix.de</u>&quot;<!--sizec--></span><!--/sizec--></i>
    Radius correction was eliminated, but the allowance was there from the beginning. I first wanted to rough and afterwards finish with the same machine. That’s why I used machining perimeter 0.
    Dec 2001
    5151
    @ Stroker
    There could be a fixed defined DR-0.2 in the tool table ( row DR in the TOOL.T)
    If nothing is visible in the program and the tool was correctly measured.
    It doesn’t seem likely that the error was in the copying...
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
