Hello
First containment is the feed after M128 - it’s responsible for the compensation motion of the linear axes.
Second containment: if nothing stands behind M128 then the MP7471.
Third containment: MP7682 Bit 5 - it states if the feed is divided onto the tool (Bit 5 onto 0) or over the involved axes (Bit 5 onto1). That means if you program Du F1000 and run in X10 mm in Z 10mm and in C80 mm, then the axes run XF100 ZF100 CF800.
Usually the C block should be run more smoothly and clearer than as it’s linearized.
Gruß<br /><!--fonto:Comic Sans MS--><span style="font-family:Comic Sans MS"><!--/fonto-->Schwindl<!--fontc--></span><!--/fontc-->
