Hello luis
Can you post a sketch to make it a bit clearer?
As long as the rotations are situated in the working plane it’s possible. So multi-axis machining where the working plane is swivelled like cycle 19/plane function is not available on the TNC155.
Otherwise you can program a rotation over the centre of the ring (your zero point) with cycle 10
TOOL CALL 1 Z S3000 F1800
M13
CYCL DEF 10.0 TURNING
CYCL DEF 10.1 ROT+10.000
LBL CALL 1
CYCL DEF 10.1 ROT+45.000
LBL CALL 1
CYCL DEF 10.1 ROT+75.000
L Z+100 FMAX M9 M5
M30
LBL 1
M3 M8
; program here the contour
LBL 0
<b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
