586,096 active members*
3,378 visitors online*
Results 1 to 3 of 3
    Hello
    I hope somebody can help me out: we have to adjust several slating milled grooves on the front side of a ring (outer Ø 780 inner -Ø 680mm and 30mm thick) but these milled groves are not evenly spaced out.
    I (working in the work preparation, but only program EPL and Turn-Plus) said that the TNC155 controller is able to do that – one can do a coordinate transformation over the rotation. The milled grooves should e.g. be written in a subprogram and then recalled several times. It’s important that the grooves don’t turn – the position to the midpoint of the ring should always stay the same.
    So my plea: please can anybody tell me if that works and how I can help the user to process it- so that he only has to enter the contour.
    Many thanks in advance
    Luis
    das Ende deiner Phantasie ist das Ende deiner Welt
    Dec 2001
    5151
    Hello luis
    Can you post a sketch to make it a bit clearer?
    As long as the rotations are situated in the working plane it’s possible. So multi-axis machining where the working plane is swivelled like cycle 19/plane function is not available on the TNC155.
    Otherwise you can program a rotation over the centre of the ring (your zero point) with cycle 10
    TOOL CALL 1 Z S3000 F1800
    M13
    CYCL DEF 10.0 TURNING
    CYCL DEF 10.1 ROT+10.000
    LBL CALL 1
    CYCL DEF 10.1 ROT+45.000
    LBL CALL 1
    CYCL DEF 10.1 ROT+75.000
    L Z+100 FMAX M9 M5
    M30
    LBL 1
    M3 M8
    ; program here the contour
    LBL 0
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
    Hello
    Thank you a lot for your help. I explained it to the operator as you said. First he did not want to try it but then he did and it worked superb!
    Regards Luis
