586,058 active members*
3,307 visitors online*
Results 1 to 1 of 1
    Dec 2012
    36
    Hello
    Thank you for entering in my post
    I will be very appreciative if you may have a look at this program I made
    I did invent myself this program with this drawing: (see attachments)
    I didn't want to use the latest cycles that iTNC530 offer as I am quite sure I will not have this version but some older-ones in the company where I will have my job trial
    so that's why I did invent that way to make the 15 holes in the center and I used polar coordinates to make those 12 m6 holes on that circumference
    I ask you to pay particular attention on the parameters I used to make that rectangular pocket about:
    allowance for side
    allowance for floor
    tool path overlap
    plunging depth
    At the end I did put a countersink to clean all the bevels that the mill leaves
    Any other suggestion according it will be very appreciative
    Thank you in advance for your help
    Attached Files Attached Files
