I suppose you unplugged everything to get the video board out? Could be that disturbing the connectors has resulted in a bad connection. The error messages can be misleading (I have found) and can lead on a wild goose chase.
Carefully inspect every plug that you pulled, and check that the wires are tight in every lead lug in the plug.
