586,061 active members*
4,436 visitors online*
    Hello
    Can you write the programs in the demo version not just with Editor or word?
    When opening programs that I created with itnc, then only weird looking signs are displayed and programmed created with the editor cannot be opened at all. Are there any possibilities?
    Regards
    Hello you have to copy the program in the programming station onto a differ part of the hard drive as word ( as you found out already) can’t work with the files from the TNC folder.
    It doesn’t matter where you copy the files to- just not the TNC folder. Then you will be able to open the file with Word =)
    Manuel
    Hello
    Regards
    Hello
    You have ruined them by opening them with an ‘’ foreign’’ editor.
    You should use a compatible editor. Cimco should be able to do it.
    Or this one:
    http://www.shera.com.au/downloads/HE...6%20Manual.pdf
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
