Hello!
I need help.
How can I program the following loop
IF
parameter value negative > 1 command
parameter value positive > 2 command
Regards
GNT
Hello!
I need help.
IF
Regards
GNT
As long as you conduct a unique command, write it in the same line. The same thing in green goes to the next line.
So that what was equal, becomes unequal.
You should look through the instruction. There’re some examples inside.
If you need more than 2 possibilities, then take the Case command. Then you’ll have as many possibilities as you like.
Hello.
I believe I explained that wrongly.
I know how I should write an IF loop. But I don’t know what should stand in clamps.
I’ve tried it with
IF(R10<0)
But it doesn’t work
How can tell the controller that it has to choose between negative and positive values?
I can’t find anything about it in Siemens documentation.
Regards
GNT
Do you mean
IF R50 ==46 GOTOF continue working
Continue working is a “label”
Regards
You have to multiply a negative value by -1!
As follows:
10*-1 = -10
<b><br />Das dringendste Problem der Technologie von heute ist nicht mehr die Befriedigung von Grundbedürfnissen und uralten Wünschen der Menschen, sondern die Beseitigung von Übeln und Schäden, welche uns die Technologie von gestern hinterlassen hat.</b><br /><br />Dennis Gabor (1900-79), ungar.-brit. Physiker, Entwickler der Holographie, 1971 Nobelpr.
Hello:
A short example:
[code]IF R10 == 0 ;Pruefung auf =0
MSG ("weder pos noch neg weil 0")
G04 F2
ELSE
