1) I am having trouble picking exact location of hole for drilling cam op. what am doing wrong?
2) Is there any info on turbo cam plug-in, besides the tutorials on the disk?
If your part is a solid it may not always pick up the right center. The same goes if the hole was made using splines and such. To work around this you use the "draw circle by three points" tool and pick 3 vertice points on the hole. It will draw a circle that you can pick the center of.:cheers:
We are trying to set the hole within.0001 - I just went into the g codes and modifed the coordinates...there has got to be a better way...
I've had similar issues. The snap control seemed to be the key. There is an option for snapping to the center of a circle which never seemed to work for me, until I realized that they want you to click on the circle, not the "Estimated center". That made all the difference. Good luck.
Ken
I wonder if your space units might be set to a default of 2 decimal places. You can check under Options/Space Units/Precision. Mine defaults to 2 decimal places. Perhaps you're having a similar problem.
Ken
Set your precision to "10" in the Drawing Setup || Space Units tab. Then, in your TurboCAD/CAM drawing space, make sure to turn on the "Center" snap.
I got TurboCAD for £15. Where can a person get a version of CAM a bit like Alphacam from them; I know that they are a South African company. I have seen ContourCAM but i'm specificly after a 2D version.
